- USA, Georgia
- Gorgon
- Infraction
- Kraton 6s
- Notorious
- Senton 3s
- Infraction 4x4
You have the Max6 G2? Do you use the app with your setup to adjust parameters?I use the same combo and also a 20T pinion. I have punch control set to 40%, which would be equivalent to setting punch at 6 out of 10 in the Hobbywing.
Any less punch control (i.e. higher punch) and the car just flips on its back at any speed when I hit full throttle.
Great info! I got a great start point without worry of temps. I bet your K6 will fly!I started with an 18T with Backflip 6s, but the temps were so low I could go up to the 20T pinion without much of a temp penalty. I tried on purpose to see how high the temps got with the 20T, but I could only get temps up to 140F after 15 minutes of full throttle runs.
