hungrybird
- Kraton 6s
It’s time to make a ramp to support the Kraton 6s . Any ideas on measurements to support the size of the 1/8 RC ? I wanted to make a ramp out of 1/2” thick plywood and use a piano hinge to have both sides usable . I’m not sure if I should cut in half and put it together , make it less wide , or leave one side longer and one shorter in length . Either way it will work as a ramp . I ll use something on the sides like a rope or chain to adjust angle . Thanks for any ideas or knowledge on the situation . A ski ramp will number two, maybe , but this one I want to be able to fold up and keep it simple . I don’t want to move around or have a 2x4 and plywood heavy piece taking up space . Right now it’s a 1/2” drywall about 2’ to 2 1/2 ft long with two bricks and a wedge support under the front area .
