- Granite
Same thing happened to me. I was unable to get the outer ring out. Contact Horizon Hobby. I was sent a new motor under warranty. Seal up your new motor so it doesn't happen again.Ok, I second time that I blew my motor bearing, and it was the front one (pinion side) again. Now I'm going for ceramic, but how can I take the front bearing off, since it has blown into pieces, and only the outer ring is in the motor, and stuck? Bread wont work, since the end cap has a hole, and the bearing is busted, so I cannot punch it with anything from the outside.
