Alejandroid93
- 4x4-Mega
Just got a arrma senton 4x4 and wanted to extend my run time. I have a lipo charger just wanna know a good size battery to go with so i don't fry the esc.
C rating is highly overstated by many LiPo battery manufactures for marketing purposes. That said it's better to play on the safe side and get a LiPo battery with the higher C rating. Rather safe then burn up your ESC or other.Does it matter 35c or 50c
This is what I use in my senton 6s blx its a 4s 7600mah 100c and it last me the whole time i'm at the track the only down fall you will have it just takes forever to charge cause the higher the # with the letter C after it it would take to drain but once it's charged it would last you a long time. You will have to cool your motor at sum point, also you cant go wrong with Venom battery's just don't throw your receipt away if anything happens to that battery they will give you a new one & I have heard they will do it with no questions ask you just call them up they give you a rma # and you send it in. Now this is what I use so use at your own risk & it will heat your motor up after running it for a long time & its pretty heavy to so you might want to stiffin your shocks more. Its pretty pricey I think I paid $150 for it but its been well worth every penny.Just got a arrma senton 4x4 and wanted to extend my run time. I have a lipo charger just wanna know a good size battery to go with so i don't fry the esc.
Mega brushed I just 2s 60c 6000mah
This is what I use in my senton 6s blx its a 4s 7600mah 100c and it last me the whole time i'm at the track the only down fall you will have it just takes forever to charge cause the higher the # with the letter C after it it would take to drain but once it's charged it would last you a long time. ...
Well if ur talking about a 3s blx truck, then I have a gensacearespammers 5000 50c lipo. Alot of guys are running these and it gives me a long run time and plenty of power. Exellant packs!Just got a arrma senton 4x4 and wanted to extend my run time. I have a lipo charger just wanna know a good size battery to go with so i don't fry the esc.
Ovonic 5200mah 3s lipo with $41, 2s only $25 great price and good lipo https://www.ampow.com/5200mah-lipo.htmlJust got a arrma senton 4x4 and wanted to extend my run time. I have a lipo charger just wanna know a good size battery to go with so i don't fry the esc.
How much run time r u getting?Well if ur talking about a 3s blx truck, then I have a gensacearespammers 5000 50c lipo. Alot of guys are running these and it gives me a long run time and plenty of power. Exellant packs!
It all depends on a lot of factors. Temp outside, driving surface, amount of throttle, etc.How much run time r u getting?
