Kraton Arrma Kraton stock body alternatives
From Target for $17. It's a 20" push toy, i just took the body off which was held by 4 screws
You don't happen to have the link for that do you? My kids will be floored if we took lightning McQueen out for a spin.
I like the body for Kraton McQueen. (y)?
Pro-Line Brute Clear Body SKU: 3521-00
I have order this body. (y)
Not sure for the colors.
A mix of Red (F) and Black or Silver (F) and Black. ?
Yvan :)
  • 0df9f834-9e7c-4311-b7d2-014dfd9b8871_1.ddfe325c4152fba5bab2de7bc9286f84.jpeg
  • 4c644401-a551-40c6-ad4c-764c9909f978_1.7f63f2099fb71383ea0fc57d32a99c18.jpeg
Yes, the spoiler and back end is one piece and snaps off. I used black marker on the body post, and set the mcqueen body on it and drilled the holes on the black marks
It's a perfect fit.
Ok, so now that there's a couple of you using it, how's this hard shell body holding up? Also, are the body mounts and brackets taking any unnecessary abuse from the rigidity of the hard body? If everything is going well after a few tumbles and spills, you could be on to something here.
The Lightning McQueen toy is on clearance at Walmart for $12.99 now. At that price, I had to pull the trigger too.
The marker trick checks out as well. I used a black sharpie and colored the mounting post. It left a mark exactly where you need to drill the holes.
Hi All - I just got a Kraton (OMFG it's fun!). I was going back and forth between a Talion and a Kraton, mostly because I wanted the Kraton's better bashing abilities but much preferred the look of the Talion. Then it occurred to me that I could just change the body...
I've found three that I like the look of. The first is a 'safe option' from Pro-Line, in that it's pre-cut, already coloured and designed for the Kraton: https://www.prolineracing.com/bodies/pre-cut-brute-bash-armor-white-body-kraton.asp
The other two are from a Russian supplier on eBay:
https://www.ebay.com/itm/unbreakabl...ma-Kraton-Nero-Fazon-1-8-Militia/202577582941
https://www.ebay.com/itm/Unbreakabl...r-Tiger-Mt4g3-Hpi-Savage-Traxxas/202577582937
One says it fits the Kraton, and it seems possible that the other can be made to fit with some work. Has anyone else tried one of their bodies? They're only on eBay and called ProBodyRC (https://www.ebay.com/sch/probodyrc/m.html).
The Militia body is my favourite, but I can't work out how they did the row of 6 lights...
The unbreakable body came in yesterday. Not bad 20 days shipping from Russia. Not sure how to “dress it up” , still need to cut it out and fit. We will have to wait and see.
Mine (the militia body) hasn't arrived yet - I'm going to send it to @MacsCDP so he can make some decals. The other thing I'm planning is cutting out the windows and replacing them with plastic mesh, as in this picture:
30929
Yea plan on doing the same to the windows. Not sure on decals yet. Maybe engrave designs a bit in the body and some sort of paint in side those. Don’t know yet. The body arrived way too fast, not that I’m complaining though. Good luck on your end and please share your success
