I am about to rebuild my diffs for the truck but I didn’t know if shims are worth it. Also how do you know when you over shim or if you need more shims
Yes very much worth it. Take a look at How to shim your Arrma diff thread for more info on shimming your Arrma diffs.I am about to rebuild my diffs for the truck but I didn’t know if shims are worth it. Also how do you know when you over shim or if you need more shims
Xmaxx diff? Or traxxas shims in a arrma diff? Your post isn’t clear.I am about to rebuild my diffs for the truck but I didn’t know if shims are worth it. Also how do you know when you over shim or if you need more shims
You do realize where you are at right? ARRMA forum.Xmaxx diff
I don’t know where is the best to get shims from
