+1. I also run with two 3S packs to keep the weight balanced.Sure it can go 80mph on stock electronics if you cool down between straight-line runs. If you plan to do a bashing session instead, I would keep the gearing under 60mph so the motor doesn’t overheat.
There is no power difference between one 6S and two 3S. I would use two 3S in that car to keep it balanced.
If you have an iPhone, this app is worth getting:
https://apps.apple.com/app/id898565895
Same here ,my infraction is 8 s and I use 2 x 3s a lot when I'm not doing a hard pass .but two lipos definitely balances out better.Sure it can go 80mph on stock electronics if you cool down between straight-line runs. If you plan to do a bashing session instead, I would keep the gearing under 60mph so the motor doesn’t overheat.
