What is the stock motor pinion tooth count on a 6S Kraton with GP4 Diffs?
So just to confirm the GP4 diffs are the spiral cut 43/10 Ring / pinion
Was not a 12-13T motor pinion what the original straight cut gear 43/13 diffs used that are a higher gearing ratio ?
Just confirming, Thank you
gp4 43/10 spiral cut correct. never had the straight cut gears. where on about the motor pinion are we or the diff pinion
Running a Kraton on the slightly smaller Backflip Lp's, HW 4274 2250 G2, 50/14 primary gearing on 4S
Was really just looking for the factory baseline ... got a handle on the rest .. till i don't :eek:
