- ST.LOUIS
- BigRock 4x4
- Mojave
- Notorious
- Senton 6s
- Senton 3s
- Typhon 6s
- Thread starter
- #21
I'll be running gp5 15/42 vs your exb 10/43.i should have a little more room To work with.appriate the info,helps me alot.
Heres 2nd rear diff housing damage from big power speedcar.hoping the larger input gear bearing with help my problem.don't want this coming apart at well over 100mph..
I'll start checking mine,,for speed a little wobble can end up be catastrophic at speed!!I just wanted to add something else I found. Both my front and rear pinions were not true, I noticed this after I got it all assembled, thought it was the cups, but the shaft was bent. I put them in the lathe and put an indicator on them .02-.026" out. I can only guess this is from the heat treat, seen it before on other small parts I had treated long time ago.
