- Florida
- BigRock 4x4
- Fireteam
- Infraction
- Kraton 8S
- Kraton 6s
- Mojave
- Senton 3s
- Typhon 3s
Hey guys, I've pretty much been through the ringer of troubleshooting, but maybe someone can still chime in and help figure this out. Last time I took my K6 out I noticed that it made very wide turns, the servo appeared to be barely turning the wheels. I held the front end off the ground & the wheels turned freely, but when placed back on the ground the front wheels barely moved. So I figured I probably just fried my servo and ordered another one. Installed new servo, set endpoints, and its still doing the same frigging thing! So from that point I narrowed it down to either ESC or Rx/Tx. I plugged my servo up while still installed in the K6 into the RX on my Fireteam. Powered on the FT and the servo moved the much more forcefully. So then I plugged the FT servo into my K6 RX and the wheels barely moved again. Lastly, I plugged in a Reedy ESC I had laying around into the K6 RX, resulted in the same sluggish servo function. So at this point I'm pretty sure it has to be the RX, it can't be anything else. I'm running a 2200kv Castle motor w/ Axial Vanguard XL esc. RX is SR315 and TX is SLT3. I'm looking at a DumboRC combo to replace the current tx/rx.
