RotorBalls
- Notorious
- Outcast 8s
- Senton 3s
So I canceled my order for a dremel tool. Honestly, it was pretty easy to cut the body out using just a box cutter with a fresh blade. I carved around the inside of the body using the mold lines. It took some time and I had to make multiple passes in some sections to cut through, but I think it turned pretty good and probably better than anything I could do with a dremel. I used my pruning scissors to get some of the bulk cut off and an exacto knife to clean up some of the lines. Some sand paper as well to smooth out some curved sections but I'm satisfied with the end result.
