My Typhon 6s has been upgraded with TLR Typhon parts including chassis, shocks, shock towers, control arm mounts, servo saver, wing and mount. It also has Hot Racing differential cases and housing front and rear and amazon aluminum chassis brace and center differential support. Finally I had a VW bug body on it. That was a blast and I loved the way it handled but when I put the 20 tooth gear in I discovered that the front end would lift at about 55-60mph.
I then changed back to the stock body and got some new gears. I also eliminated 56grams from the rotating assembly by swapping to a center spool. That and the new ring and pinions (From I think the infraction) upped my top speed and I found that I still had problems with the front end lifting at 84mph. That wouldn't do so I ordered some carbon fiber limitless shock towers and limitless shocks. I also got the front bumper from the Infraction and the waterfall tower and splitter from the limitless and build a front bumper for the car. Finally I mounted a Corvette body on it. I took it out this afternoon and hit 94MPH but had to lift when the body started dragging the road. I need to do some work finding or building better side supports that reach out to the edge of the body. Something like a belly-pan and rear diffuser that I can Velcro the sides of the body to.
See 94MPH run here
