Mr.Duke
Moderator
Community Leader
ArrmaForum Fan
- NC
- Infraction
- Limitless
- Kraton 6s
- Notorious
- Outcast 6s
- Talion
- Typhon 6s
For the last year or so, I’ve been experimenting with ways to resolve the issue of breaking fan blades in the ESC, whether it’s the BLX 185 or HW Max6.
What I’ve found is that on some hard impacts the tips of the blades will make contact with the underside of the guard above the fan. This seems to be much more of an issue with the Max6 but it applies to both.
This leads to the tips being chipped and eventually breaking the blade itself where it connects closer to the center of the fan.
I went from breaking fan blades about every 3rd pack to only breaking 2 in the last 8 months. I’ve had a couple other fans fail but that was due to the wires coming loose at the fan itself.
There are 2 modifications that I make that in conjunction has helped the fans live much longer.
The 1st...
Take a small square of fiberglass screening, same as what’s on a window screen or a screened in porch, and cut 4 holes for the screws to poke through.
This adds a soft but somewhat effective barrier between the fan blades and the housing above.
This can improve the life without modifying the fan blade itself, but I’ve found that doing both work very well together.
2nd - Clipping the Tips and Profiling
This may look like a pain but it’s really not.
What it accomplishes is that in the event the blade does come into contact with the fan guard, the revised profile keeps from breaking the blade off
First take a small pair of side cutters and clip the tip off an a triangle pattern on the side of the fan that faces up. Try to be as consistent as possible when removing any material as it can produce a slight imbalance if one weighs significantly more or less than the others.
take a small file and profile the leading edge of the blade so that it’s round
Do the same on each fan blade.
New fan on the left, modified one on the right
Hopefully others will find this helpful in extending the life of their ESC fans.
The 1st...
