Tire foam inserts
Today I baked the tire and wheel in oven to separate and I was right the insert was ripped. Someone has to make a foam insert. There 3in wide 15in long
Arrma will replace it for you or you can just buy a set of two stock tires.
Got all four tires off wheels, inserts were shot. I found a set of kraton inserts that are close
You are lucky ! See my post about my tires problem and electronics problem ;-)
I saw I'm very sorry maybe it has something to do with being in America. They have done things for me that I would never expect.
Thanks arrma for no warranty on tires
New foam inserts
Usually 20 min at 325 to 350 on a cookie sheet. After all this in taping tires and adding new inserts. Hopefully it fixes my problems. Didn't have this issue till I started pushing my truck to 65 on pavement.
