Kraton Tekno ET48 shocks
lemonteksunrise
Trying to find a fully built set of Tekno ET48 shocks to put on my Kraton and haven't been able to find a set anywhere. I'd rather not have to buy piece by piece from Tekno to build the shocks. Any similar shock sets to the ET48's that come pre-built? Looking for a quality high end upgrade on the shocks.
Closest I've found is JRC..not ET48, but they had MT410.. may be sold out, IDK.
https://jennysrc.com/collections/tekno-mt410-monster-tkr5603
Also, JRC has Mugen parts..they're synonymous with quality too👍
BTW, what problems are you having with the Arrma shocks? I've found them to be quite good? Not crazy for the rod ends, I've broken a couple, but they're not terrible.
Yeah what @KnowAir said.
If you want a better shock just get the internals out of the TLR Typhon and the M2C shock caps the Arrma shocks are already race spec they just don't have tini shafts.
Rod ends breaking. Looking for something more robust.
Thanks for the info I’ll definitely look into that.
You can use Tekno spring cups and rod ends/pivot balls on Arrma shocks too.. I have them on the front of my Kraton exb with stock Arrma shocks.
You'll sacrifice a bit of adjustability since the Tekno spring cups are shorter than Arrma's, which required me to thread the preload adjusters down quite a bit to get proper spring preload but totally workable.
I couldn't get the balls to fit into the arms on mine for some reason. They fit on my Outcast but not the EXB. 🤷‍♂️
Ended up going with M2C shock cap bladderless set.
I don't recall specifically, but I probably drilled the arms out to fit the Tekno pivot balls.🤷‍♂️
I also fitted some TC sway bar links and pivot balls on it, definitely do remember drilling the arms for those, had to hog them out quite a bit, LOL.
I don't think I had any problems fitting the Tekno pivot balls..
I saw a couple cods where people liked 60wt oil and the Tekno 90mm orange springs on the stock arrma shocks . Did you come up with a solution ?
Any information about the Tekno shocks is outdated. The Tekno orange springs are softer than the stock Arrma springs.
I don't think you can get those shocks kitted anymore. Only way to get them now is hope someone is parting out an E/Nt48.3, E/NB48.4 or a MT10 V1 or buy them piece by piece but that will cost you quite a lot.
IDK how much the 2.0 varies from the 48.3, but JRC has had the 2.0 versions, OOS now though.
I like the Tekno shocks on my MT410 and SCT410.3, but TBH, nothing special in my experience. They leak, more than my Arrma shocks, which are older..
IDK either. I haven't found what the length of the shocks are. I am over on the Tekno forums I supposed I could ask. I've never had issues with mine leaking. They are much smoother and the guides hold up much longer than the Arrma shocks do as well.
I've got a couple that are leaking. However I have to admit the rod ends, pivot ball and cap bushings last longer than Arrma's. I like shocks that work, which obviously both the brands we're talking about do well. I just prefer the Arrma shock because they're so readily available and cheap from kit breakers I guess.Aside from the bushings and rod ends, Arrma's shocks are perfect for me. I do see what you mean about the Arrma shocks though, where the spacer bushing and piston start wearing and the shaft wobbles..as long as it doesn't leak, I'm happy. I don't get into shock rebuilding, just fluid changes, then toss and buy new when needed. LOL.
