Typhon Stretched Typhon TLR Castle 2028 build
kyoto
Washington
  2. Mojave
  3. Typhon TLR
Just finished buttoning up my stretched typhon build. Just waiting on my side guards to come in.
Nice! So I see you added the front limitless body pin set up thingy...Can you take a pic from the side I am curious as to how the body rides on it instead of the conventional mount. What battery tray tires?
The mount is actually off of the kraton which allows me to run the tower to tower center brace. I had to cut a new hole in my body since the body post was moved forward about 10mm and it sits higher than the stock one. The battery straps came with my integy battery tray.
First, are you sure that's enough motor for that car??
Second, is there anything to keep your batteries from sliding backward?
No I need more motor 😂 But the battery trays came with an aluminum piece to prevent batteries from sliding back, I just realized it came with it after installing it. Planning on putting it on when i get my side guards.
