Povell42
- Granite
- 4x4-Mega
Just changing the servo doesn't fix the servo saver from frequent slipping. I really dislike the granite servo saver design, as my son constantly slips the saver causing the wheels to lock either left or right. The only solution is to take the electronic box out, pull off the servo saver, readjust and Center it, and then put it back together. I tighten the top screw significantly tight and I do not have a screw in the back... as I've made that mistake also and stripped out my Savox metal gear servo.
Has anybody put a spring loaded Servo saver, similar to Traxxas, into their granite? I never have this issue with my Rustler as it has a better Servo saver setup.
