milehighspeed
i have my typhon 3s set up exactly this way. its works just fine. just also put some tape underneath to keep those vibrations limited as well. here is a great link to set up and calibration from spektrum.Oh...yea I just stuck it to the side of the rx box. Its too long to fit as the slr300 did flat on bottom. So how would should I mount it and know it'll be still standing after a good cartwheel?
I went thru the process. Gyro seemed to be working. But I had the motor wires unplugged. Rx light nvr went off. So I plugged it all back in. Turned on truck hit bind button on rx and it went full throttle without touching anything. Good thing I had the center drive shaft out. That way I caught the thing. And was smart enough to have it level off the ground tho
the issue you described about the car taking off during calibration i suffered one time and it was because i had plugged the steering into the upper most receiver slot by accident (the only concern of this tight upright mounting in the box is you cant see very well) and then the throttle immediately below which put the throttle into the steering. this threw off the sequence of calibration and when i turned the wheel it instead read that as throttle input and off she went. disaster across my work bench!!! make sure you have things plugged into the right slots and note that the upper most slot is for batt/prog and should be left open.
