Mike488460
Apparently the vorteks i have came with firmware v1.25 (and most likely the rest of you) so I decided to hook up the ESC program box up to the computer and update that (because I haven't done it in a long time) and then got the idea to hook up the firma to the spektrum programmer on the computer just to see what settings I could mess around with and wow there is not much adjustability.... Like at all lol... So I scrolled over to firmware update and was surprised to see that there was an update to 2.06(it said it was a public beta) I did that and now you can change bec settings (for servo) from the fixed 6.0 to 7.4 .... What really intrigued me was the motor timing was now adjustable so I bumped it all the way up to 26 from 23 going to take it for a test run I also changed my brake settings on old fw it was set at 62.5 it seems like they did some tweaking and the asterisk * is usually the setting that would come with that firmware or from factory so it was set at 37.5 on fw version 2.06 so I went to 50. I'll see how it feels and if I don't like it I'll go back to 62.5 but you have more settings for brake now ill post a couple screenies and let you guys know how it runs
