- Kraton 4s
- Raider
thx i'll see if i can find a kit or two that contains all of those sizes.No just a combo of a few. There a few videos on it and a few pictures that go over the sizes posted up here. Check out sticky threads in chassis and drivetrain and your user manual. Not completely sure who posted this picture but i took a screen shot of it to reference while shopping. Actually looking at it I believe Notorious J gets the credits. Thanks @Notorious J
Thanks for sharing the spreadsheet, makes for a much easier for me to have that saved on my phone to reference when attempting to locate specific shims bearings and hardware for sure.Hi everyone.
I transferred the information from this, along with some addtitional products I have found along the way into a spreadsheet. Thought it was only fair to share it.
I have also slowly been fleshing out the list of fixings as I prefer to order them individually from reputable screw suppliers, but it is by no means an exhaustive list (yet).
There is a bearings list, but this is also just a few items included here so I have all the information I need, quick to hand.
Happy to flesh the thing out with further data or comments if people have them.
https://docs.google.com/spreadsheets/d/1hsQBVZHxqyHskx2CS3niMWIqGJePsbG1hEpCDrVZXFM/edit?usp=sharing
Hi everyone.
The mugen set has everything you'll need for shimming all 3 diffs. It's a great set with really high quality shims. It's what I use. If you want to shim the outside of the diff to tighten up the mesh on your outdrive, get the kyosho 13,16,0.5 shims. They re the first shims on this list I believe. ??I have ordered the Mugen 0206 set for my 18 typhon. Is the 13x16x.15 shims the only other shim I need to order???
That kit is missing shims for the larger sun gears.PLEASE CAN SOMEONE HELP ME??? so iv been searching for a few weeks now for the shim kits to do my v2 kraton diffs and nowhere has them in stock in the uk...if came across this post and iv checked ebay and they have the "associated AS81381" kit in stock, would this be enough to do all 3 internal diffs ? planetary gears and the spider gears pleas someone help me out it's doing hype but in now lol...
Which shims are needed for the notorious input gear?
5x7x.2?
Hi everyone.
Hi Oceanminded,I know there are a ton of videos /threads on this but for someone shimming diffs and changing oil for the first time on a Kraton 6s V4 what shims do I need to order to do everything. I know there are multiple choices/sizes that serve the same purpose but for someone new It would be great if someonecan just list the most popular choice of what I need so I'm not ordering mutiple sizes making things more complicated for the first go around.
Thanks!
Thanks for the info. After watching more videos I think I'm finally getting it. It seems to do a basic shim and oil change job on the 6sv4 all I would need is the Mugen Seiki E0206 kit and the Kyosho 96772 13x16x.15mm kit for shims. What else am I missing? Are the above items you mentioned to do the same thing or is it for a different part of the truck like where the driveshafts are located outside the gearbox.Hi Oceanminded,
I know it can all be a little bit daunting at first.
Part of my deconstruction of information process was to make the spreadsheet that I eventually shared, and you can access with all the part numbers listed above.
One of the issues with, a "buy this" approach is stock. Many of the kits that's fulfill multiple purposes arent available in some countries, or aren't available at all, same as some individual shims.
I can, however, list my favourites:
Between output drive cup and the diff case
5x7 (These are widely available in many kits, very common RC shim size. E.g. KYO96643)
The Sun gears
KYO96774 5x20x0.2(I out this on first)
DIN988 5X10X0.1 (if more shimming is needed, the stock ones that come out of the newer arrma diffs are also fine, but 0.24 thick)
The Spider Gears
SW 101004 3.5x10x0.2 (Although just go for the CoreRC ones, or Stock Arrma if you have to wait weeks for delivery of these... they're just my favourite so far)
Between the output cup bearing and the plastic gearbox
KYO96772 (Could also go for UR1124 or CR456 if they're easier to get hold of)
Input Gear, behind the large bearing inside the gearbox
DIN988 13X19X0.2
I believe you are missing just the one shim mentioned and IMO can be very important which is the 5x7mm shims for the outdrives. This keeps the outdrives from moving side to side through the 8internals of the differential but the shim is visible from the outside of the differential itself. I'll attach the image that I think is easiest to understand. But the info originally provided was absolutely excellent in comparison to others that can get a bit confusing for some that are not so familiar with rc differentials. Shout out to @B1scu1T forproviding such information (even a guy who hates spreadsheets actually very much liked the one he created for suggested parts shims bearing etc lol) well done and appreciate the time taken to provide the explanations @B1scu1T . The shims I believe you werent including are the 5x7mm that point to the two outdrive in the image. Hope that makes sense in a bit of a rush sryThanks for the info. After watching more videos I think I'm finally getting it. It seems to do a basic shim and oil change job on the 6sv4 all I would need is the Mugen Seiki E0206 kit and the Kyosho 96772 13x16x.15mm kit for shims. What else am I missing? Are the above items you mentioned to do the same thing or is it for a different part of the truck like where the driveshafts are located outside the gearbox.
