Gdub34
My buggy, 6sv5 typhon, uses the spektrum firma 150 amp esc. I read the manual but did not see how or if you need to adjust lvc? I know it’s parameter 1 of the 5 you can adjust but the manual only gives lipo as the only option. Is this esc programmed from the factory to go into lvc when the battery hits 3.7 volts? and do I even need to worry about setting lvc at all?
I’m leaving the rest of the factory esc settings alone except for punch after I get use to 6s powerthanks
