Howdy gang-
So my Kraton started having an interesting issue a while back - while running the servo saver will loosen up. I can do the whole Allen key thru the hole in the bottom of the chassis and tighten it down real good, but it just works loose again, and pretty quick too - I have to tighten it 2-3 times per battery. If I don't catch it in time, the adjustment nut will jam against the chassis, and lock the whole SS from turning - which can only be fixed with a full tear down.
Anyone else see this problem? I don't want to use locktite on that screw (done that before on different models, the loctite goes everywhere and gums up the works). I am thinking of teflon tape, next teardown. But why did it start doing this? This is an older V1 Kraton, with lots of use. I am guessing something in there is worn out, but not sure what.
