takingchances
What’s the best upgrade to get great speeds out of a senton 3s blx
+1. Gear up.Bigger pinion gear is best way, but know the motor will get hotter so proper cooling will be needed if running the rig hard.
Have one. Above speaks truth. Convert to cereal box shell to eliminate parachuting.+1. Gear up.
The Senton is already plenty fast out the box for what it is, especially with the speed gearing. Not sure if you'd really wanna go much faster with a SCT, the body tends to act like a parachute the faster you go.
Yea experiencing the parachute issue now even after making some cut outs on the body , I’ve seen some one use a big rock body on there when doing speed runs and actually make a huge difference when it come to the parachute issue+1. Gear up.
