Limitless Retractable Antenna?
kaladeth
Rig of the Month Winner
Mountain View, CA
  1. BigRock 4x4
  2. Limitless
Got a box that fits perfect, except I forgot about the d*mn antenna. 🤦‍♂️
Un screw the grub and the stick/ tube that holds it will lay down. If you didn't know this.
Haha yes I could just pull the tube out and lay it flat during transport. Over engineering brain. 🤭
Almost started designing a servo-actuated folding antenna 😂.
Or cut a hole let it poke through. Build a smaller box on top.
Yeah, that's what I meant. There was actually more to my post than 2009 flashback humor.
If you want to ditch your cardboard box, try the IKEA frakta bag. I don't know if the limitless is longer than the VTE2 tho. It also has carrying handles. I put in a wooden bottom plate to make it somewhat sturdy.
And the antenna too long problem would be solved:)
@Lennart - Thanks, the Limitless is 73.66 cm long and would probably fit in that bag, but I needed something stackable. I have two Limitless that I am trying to fit into the trunk of my car, not to exceed 44.45 cm.
