davmbar
I recently installed a traxxas 12t brushed motor in my fury and found the plastic spur gear has a section of teeth worn out after using it twice. Is there an aluminum spur gear i can replace the plastic one with? Or do i just replace it with the same 87 tooth plastic spur gear? Anything else i should replace like the slipper pads?? Thank you
