Recommended Tire Glue
Glad I found this post. I had a front Proline bad land come flying off the outside bead of my Sketer. I could only go half throttle before seeing the white foam insert flopping around. I used Gorilla glue, but that didn't hold at full throttle sadly:(. Guess I'll try the ic2000.
IC2000 is amazing stuff as is a lot of the CA glues that Bob Smith Industries manufactures. It is so good in fact that BSI is the OEM for a lot of our rc tire glue that is sold under other brands.
They even do custom labels for hobby stores.
This is first party BSI IC2000 for reference.
Do you prep the tire or rim of the wheel before gluing?
Others here may have different procedures, but I just wipe the area to be glued with alcohol to ensure the majority of dirt & impurities are removed.
Ditto.
