Notorious Rear sway bar
New Jersey
  1. BigRock 4x4
  2. Kraton 8S
  3. Notorious
So I’m getting around to swapping the diff oil in the notorious and did the front and rear successfully already. The front sway was a bit of a pain, but it was figured out. The rear looks a pain because I’m not sure how to get a hex driver in there with the rock guards in the way
Any recommendations to getting the rear sway disconnected enough to remove the rear diff?
Thanks everyone,
KW
You gunna have to get those screws turned up so you can reach them with a driver eventually. Prolly could have had the job done in the amount of time it took to create this thread. You can take one side off OR if there is room to push it over the housing but don't bust anything trying to do it the quick way, that always sucks.
I just replaced the rear a-arm on my Notorious. I install the link before I install the arm. After the arm is installed then I pop the sway bar ball in place. This seems to work pretty well.
