Virginia mud
My input gear went out what is a good replacement? Everything else back there looks good.
Mine too. Hot racing has one but the whole kit is like 100 bucks and arrma has a metal one and the whole kit is like 50. I have a hot racing in the rear and have some spares so when I burn up my spares I’ll get the arrma one to see which one is better. Hot racing had a spiral cut and arrma is just straightMy input gear went out what is a good replacement? Everything else back there looks good.
Put shim behind it alsoMy input gear went out what is a good replacement? Everything else back there looks good.
If you but shim behind it, it will take any slop you had be hone. Thats why they break. I've been running stick input hear 2 yrs now no problemsMine too. Hot racing has one but the whole kit is like 100 bucks and arrma has a metal one and the whole kit is like 50. I have a hot racing in the rear and have some spares so when I burn up my spares I’ll get the arrma one to see which one is better. Hot racing had a spiral cut and arrma is just straight
Question: when shimming an input gear, does the shim go inside the INNER bearing?Put shim behind it also
