Hello, I am pretty new to RC and completely new to larger scale. I got a new Kraton 6S Exb recently and I am having some issue with the batteries I bought in advance for it. So I will post some pics with them attached so you guys can see wether they are mounted on there securely or not.
I got three batteries. Two Cnhl 4S and one 6S. The 6S fits good in there but the other two I am concerned about. Especially the 4S G plus 6000mah. It's like almost 170 mm long, 60mm wide and 33mm in height. I have to put the 33mm side sideways obviously because 60mm is way to wide. The problem with this is that it becomes to narrow with only 33cm sideways. You'll see in the pics.
With the Racing 4S and 6S version, it's no problem with width. But basically the length might be. They are about 165mm. All three are longer than 158 I think Arrmas max is. People say length isn't a problem but I'm concerned that the final bit will be exposed when driving. Here are the pics:
