Outcast Outcast V2.5 Heating issue
Something else I've been thinking as far as rolling resistance, most of my runs so far have been in the yard and while the grass isn't knee high by any means, it is taller and thicker, needs to be mowed just haven't done it yet. Would that cause enough rolling resistance to heat it up?
I bought my first arrma last week, decided on the 4s outcast v2.5. I have 2 losi lmt mega trucks 4s so didn't want to have to start over again on batteries. I binded the outcast to my spektrum dx5 rugged out of the box. Sunday I drove the truck for the first time playing around in the back yard and noticed the motor temp on my radio showed roughly 240 degrees. I pulled the body off and you could definitely feel the heat from the motor as well as the battery. I'm running spektrum 4s 5000mah 100c batteries. So I looked around and researched as much as I could and many said the fans that come on these trucks are better than nothing but not by much. I installed surpass rocket fans on the motor and esc. Took the truck out again today and max motor temp I seen was 208 degrees if running it really hard. It cools down very quickly with the rocket fan but still that seems pretty dang hot to me. Battery temp was 143 degrees when I called it quits and let the truck just sit with the fans on to cool off. Truck is bone stock aside from fans. I have a spektrum box to change settings but all settings are stock. I made sure nothing was binding in the drive train and it rolls freely. While it does roll freely I notice a pretty audible clicking/popping which I'm assuming is the center diff? I checked the mesh on the motor pinion and it has slack/isn't dead tight up against the diff gear. Anyone else have this issue or know where to go now? I absolutely love the truck but don't want to melt stuff out of the gate. Thank y'all!
Did you do 2 fans on the motor? If so what make and fan size! I might need these.
Yes, the length of the grass has quite some impact om the resistance and with that the top speed.
I know that question sounded stupid to a degree but I was thinking about it due to needing to mow the yard and realizing the grass is taller and thicker than I thought 😂
Took the truck apart today to do the diffs and install my M2C racing motor plate, all of the stock bearings checked good....except the 2 on the center differential housing, they were gritty and toast
Just got done running it in the back yard pretty hard, grass definitely needs to be mowed. Temp gun to the differential side/motor plate of the motor was over 200 degrees at the end of the run 🤦🏻‍♂️ and motor plate was really hot, starting to wonder if there's something going on in the differential itself causing extra strain and heat
Update 4/29
Over the weekend I installed a dual 30mm fan kit to the motor with dual 30mm rocket fans. Test drove Saturday evening around the yard in shorter grass, truck still got pretty warm. Yesterday (sunday) I took it to a large gravel parking lot which you would think would be less resistance than grass. Motor still got very hot to the point you couldn't leave a finger on it long at all. I pulled the motor and checked it for any excessive play on the shaft or excessive rolling resistance on the pinion by hand. Everything checked good, but that's not to say the motor bearings arent failing. Had another bearing on the center diff turn up gritty but as hot as the motor got both days I don't see this being the cause. Really starting to think the issue is in the motor itself
