Outcast "TALL" side guards ......
Big Kid
Old Hangtown .... USA
Without a doubt improved debris protection while also giving some more side impact rigidity.
Only downside appears to be if taking your motor In / Out frequently, clearance afforded might be a tad tight ?
:unsure:
Do you have to modify them to fit on the kraton?
In my case of having a V2 belly pan which has the long taper on rear section it was a perfect fit. V3 /4 & Exb I think are similar :unsure:
As I recall seeing, V5 has the shorter faster taper rear section that would require some plastic trimming of the guards to match the different angle.
