Other 6s shock spring options
Velodromed
Snatching defeat from the jaws of victory!
San Antonio, TX
  1. BigRock 4x4
  2. Granite
  3. Kraton 6s
  4. Kraton 4s
  5. Notorious
  6. Outcast 4s
  7. Vorteks
  8. Voltage
  9. Infraction 4x4
Specifically for the Kraton. Im looking for heavier weight rear springs and lighter weight front springs. I know team associated yellow fit but am unaware of other brands that may. Any help is greatly appreciated.
Oh, This is for my 4S build. I used front and rear stock 6s Kraton shocks.
Have you looked through this thread yet? https://www.arrmaforum.com/threads/...or-4s-and-most-6s-vehicles.18704/#post-286478
the Tekno 48 series shock springs fit on the Arrma shocks as well.
Thank you. No I hadn’t found that thread.
Leads me to another question. The front stock springs are 85 mm and the techno are 70mm. Will they still work?
I’ll read through and review the rest of that thread as well. Again, thanks.
I use the firmer Fireteam springs on both my Kraton & Outcast rear shocks. I find this combo works very well. I leave the front springs stock FYI.
Thank you. I’ll go look up the specs on those. I have not thought of the fire team yet.
So, you use the front fire team shocks on the rear shocks of your Kraton? I noticed that the rear fireteam springs are only 70mm, but the fronts are 85 mm. The kraton takes 95 mm stock springs in the rear… sorry for my confusion I’m just trying to figure this out. I’ve always assume that you have to use the same length springs that come with a stock shock. Maybe I’m wrong here?
I believe Hot-racing makes some.
You can also use Nero springs possibly?
Arrma #AR330419
65mm shock spring (2) 503gf/mm 28.1667 lb/in
Arrma #AR330417
75mm shock spring (2) 317gf/mm 17.75 lb/in
Arrma #AR330347
65mm shock spring (2) 420gf/mm 23 lb/in
Kraton 6s
Kraton front springs 85mm (ar330507) 6.2 lb/in (110.7 g/mm)
Kraton rear springs 95mm (ar330508) 5.0 lb/in (89 g/mm)
Limitless/Infraction/Felony
35mm 27 lb/in ARA330600 (front)
40mm 38 lb/in ARA330599 (rear)
optional springs
35mm 32 lb/in ARA330630 (front option)
35mm 38 lb/in ARA330631 (front option2)
Other random info
Arrma Kraton V1 & V2:
Front: AR330195 119mm
Rear: AR330251 142mm
Arrma Kraton V3:
Front: AR330490 114mm
Rear: AR330481 134mm
Arrma Outcast V1:
Arrma Outcast V2:
Arrma Talion V1 & V2:
Arrma Talion V3:
Front: AR330496 107mm
Rear: AR330497 124mm
Arrma Typhon V1 & V2:
Front: AR330207 105mm
Rear: AR330195 119mm
Arrma Typhon V3:
Front: AR330477 107mm
Rear: AR330479 120mm
Arrma Senton 6S BXL V1 & V2:
Front: AR330376 101mm
Rear: AR330207 105mm
Collars are adjustable, pretty much any length you want in that spectrum of springs..
Can work.
Just depends on how much "spring preload" adjusting may be required. If you require a lot of preload, 70mm could fall a bit too short? With a lighter 4x4 rig, you may not need much spring preload? Ultimately depends on the chosen Spring Rate where your preload ends up. And how much sag you want.
So it is trial and error for the most part. Springs can get tricky. And depends how anal you are with your shock setup.:LOL:
Tekno springs are well made from good spring steel. FWIW.
Can work.
Thanks Steve! I get what you mean. Hadn’t occurred to me to use preload to make up for length.
It’s for a approx 9lb 4s build…
Got it. That just hadn’t occurred to me…
Arrma #AR330419
Arrma #AR330417
Arrma #AR330347
Kraton 6s
optional springs
Other random info
Arrma Kraton V3:
Arrma Outcast V1:
Arrma Outcast V2:
Arrma Talion V3:
Arrma Typhon V3:
Thank you!! I’ve been referencing back and for between the Arrma site (car breakdowns) and then looking up the spring rate on horizon. Much slower that way is.
Arrma #AR330419
Arrma #AR330417
Arrma #AR330347
Kraton 6s
optional springs
Other random info
Arrma Kraton V3:
Arrma Outcast V1:
Arrma Outcast V2:
Arrma Talion V3:
Arrma Typhon V3:
Basically it could be as simple as taking the front springs (Kraton front springs 85mm (ar330507) 6.2 lb/in (110.7 g/mm) and throwing them on back.
Man…I really learned something here, thanks to you guys, about shocks. In my mind you had to use the equivalent size spring that was provided stock. Just didn’t occurred to me could do otherwise for some goofy reason. Thank you! This mean I probably already have the springs I need to do this 😊
Um no I just measured mine off shock85mm front 95mm rear
What is stock wire diameter and weight rating
