Big Rock Old school Nero
Cheez
So. Cal.
  1. Kraton EXB
  2. Mojave EXB
  3. Nero
  4. Senton 3s
Hey old schoolers,
I’m doing a long overdue total overhaul/ maintenance of my Nero. first of probably many issues to come is needing this. Arrrgh! I’m not seeing the screw pin part number.
I’ve got a bunch, but nothing exactly the same.
part number?
Do yourself a huge favor and replace all those Arrma drive pins with Traxxas 5145 instead. You’ll need 8 to complete entire rig. No mods needed.
Been too long...since center diff maintenance. Manual is foggy...
what screws am I removing ?
Never mind. I think I have it.
Still stumped...not seeing what manual is doing... trying to remove center diff.
I’m completely tearing down and rebuilding all three diffs. I’ve searched threads and there’s lots of opinions, regarding oil weights, I’m hopeful someone with Nero experience will inform me. Right now 20K is all I have.
The nero with the diff brain doesn't have diff oil in the diffs. The locking pins actuated by the diff servos doesn't allow fluid to to remain in the diffs. I hope this helps.
Actually it does? or I should say that when I opened them they had oil/grease in them.
Sorry I’m such a doofus ? , so this is what was probably in there?
Funny you should ask....I’ve been working on it every day,Completely rebuilt center diff and did maintenance on the others, just now put motor/center diff/servo back together. One of the diff servos is dead.
I left it out of the front diff. I left the locker in, in open position. Is that a bad idea? Can’t get a new one until October. Did a light bench test with no wheels/ minimal acceleration and drive line including slipper clutch seems to be okay. I’m not going to button it up yet because I’m waiting on a new roll hoop.
What are the small bearings for? Sorry for my ignorance, I just haven’t come across these in the rig. Maybe I’m blind?
I guess for nostalgia sake I should have done photos of the process.
On my Nero HD build, I removed the servo and lock pin mechanism from both front and rear diffs. Basically, just the diff assembly and bearings are still in the plastic housing and nothing else.
So is the lock pin going to move around creating a problem? If I take it out wont grease leak out?
btw I figured out what those bearings are for. The rockers, mine are still stock, I’ll swap them out
