Kraton New Kraton EXB RX/TX issue?
dgitalchaos
Military Veteran
  1. Infraction
  3. Typhon 6s
First time I turned on my new EXB, the radio sounded like the theme song to Stranger Things. I didn’t think much, but running it yesterday, it kept beeping randomly. Today, all it does is the Stranger Things beep. I can’t calibrate the ESC, even with AVC off on the receiver. I tried the Typhon RX/TX and the Outcast 4S RX/TX. Just won’t do anything. I can still adjust settings on the V2 programmer, but I think it’s RX/TX related. Will try a Traxxas RX/TX in a little bit.
Did you pull the servo JST out and attempt?
Motor wires tight?
Motor wires tight?
Yes I did. ESC is blinking red, which means it’s not getting a signal from the receiver. Trying my Traxxas receiver in a minute…
Also means ESC is junk.
I got it to work. The Traxxas receiver worked to calibrate the ESC, then I used the stock RX/TX. I reset the Transmitter (TX) to factory, and recalibrated the receiver (RX) with AVC. Everything works now and I was able to also calibrate the ESC with the stock RX/TX. Hopefully it doesn’t give me any more issues.
