Kraton83
- Kraton 6s
Hey all,
Just wanted to make a post about some of the mods I've done to my Spektrum DX5c. I picked this up initially for a Limitless/Infraction build because I wanted to try the spektrum AVC and telemetry (mainly mph and pack voltage). After I got it I found out that the range is not great for speed running and it there wasn't a factory option for powering it with a 2s lipo like I thought. So I decided to see what I could do about both.
Despite there being nothing in the manual or anywhere else online confirming of the DX5c could handle more than 6 volts I found 1 video on youtube showing someone adding a 2s lipo so that's the first mod I did. Remove 2 screws and the battery tray comes out and you can snip the wires to solder on whatever power lead you want. I took it a step further and took apart the transmitter, desoldered the battery tray leads from the voltage regulator, and soldered in a JST plug that disconnects from an XT60 plug. The 2s lipos I have to use were originally for my fpv goggles and a tad too big so I had to trim some plastic in the battery tray but all said and done it now runs on a 3000mah 5c 2s lipo.
When I had the DX5c apart I noticed that the radio module actually had a second unused IPX antenna connection. This would indicate that the radio was capable of diversity but again found nothing online to confirm that.
To test I set up an esc, motor, servo, and spektrum receiver on the bench. Before changing anything I confirmed that the signal was good all the way across my house. I then disconnected the factory antenna completely and without any antennas connected the range was only about 5 feet then stopped. I then plugged the factory antenna into Antenna B and the signal reached all the way across my house again. This confirmed that Antenna B actually did something.
So I took a IPX to SMA antenna cable and drilled a hole next to the stock antenna and reassembled. I now have the ability to add a second antenna for better range which I will be testing later on. In addition I've ordered a 2MW booster that can be powered by 5v and conveniently the DX5c has a data port that can supply the 5 volts already on the side under a panel and is easily connected by a normal servo plug or JST plug.
Anyways I think it came out really clean and hopefully everything tests well. If so then this eliminates one of the biggest shortcomings of the spektrum compared to other radios in its class.
Is there any range improvement with the extra antenna intall with out the Range Booster???
I having issues with my DX5C/SR515 setup at 200ft/60meters loosing range
