Kraton my kraton so far....
Josh nortz
Farmington NY
☆My kraton☆
GKA chassis braces and servo mount, savox 1231sg 444oz/in @6.0v, center diff mount is a motor mount cut off, 14 tooth pinion, Pro-Line badlands, Tekno 90mm orange Springs on all 4 corners, 60wt rear shock oil and 70wt front, front diff 50k, center diff 100k, rear diff 100k, diffs pinion gears shimmed, have a brand new MMX ESC on the way to put in it and some spacers from GKA for the taller servo. also has a spektrum srs 4210 AVC receiver/
it's a tight fit, when I take it apart I will be grinding off about 1mm on the inside of the center diff mount to give the diff cup a bit more clearance. other than that it's perfect.
