- Notorious
- Talion
- Typhon 6s
I've had my Max6 for a little over a year, probably put close to 100 packs through it. Cannot seem to avoid thermal cutoff when I bash lately. Running it my Talion with a 4092 Hobbystar 1480kv with 19/46 gearing on 6s with Backflip LPs. Basicially a lot of dirt bashing at high speeds, no jumping. Previously the only heat issues I had was motor getting too hot. Went to double 40mm fans and dropped from a 21t to a 19t pinion and now the motor doesn't exceed 150, usually in the 130s-140s. The esc is usually in the 120s except the cap packs go to the 180s and cause thermal shutdown. All 3 caps are usually within 5 degrees of each other.
I can make it over halfway through a 6000mah 6s battery before it cuts off. I cool it down to below 90 and try again but the second cutoff happens much faster. Any fixes for this? Would adding a cap pack could keep it cool? Extra fan on the caps? Anything else?
