Are you guys using some sort of a magnfiying glass for your hobby? Like the ones you attach to a desk.
Was thinking about getting one for soldering and to adjust the pinion/spur mesh.
But not quite sure if it is nonsense.
Diopter 3 I guess? 5 could be a bit too close to solder.
Large is like 4 inch glass diameter?
This is exactly what I have.
Do you need one to see better? Then it is necessary and useful to you. Why do you ask us? Why would you need our opinion?Are you guys using some sort of a magnfiying glass for your hobby? Like the ones you attach to a desk.
But not quite sure if it is unnecessary.
I have a small magnifying glass - mostly use it to check differential gears. Not sure if a bigger on is just another gadget that I can do without. Or one of those where I wish I would have gotten it long ago. It does take up some space. My main workarea is a table 80x120cm with 4 wheels that I can move and walk around. So a cable is quite irritating. So many write on Amazon they are pretty wobbly. I will have to remove it now and then.Do you need one to see better? Then it is necessary and useful to you. Why do you ask us? Why would you need our opinion?
I would get one in a heartbeat if it would help me see.
Will have to check / figure out what size makes sense.I've seen some that's bigger.. 6-8"
But use whatever works for you.
We've got the same one @Tex Koder posted. Its pretty stable. I find it helpful and I don't wear glasses. For me its 1 of those things I don't need that often, but when u do I'm super glad to have it.
I have one of the clamp ones. Love it!Are you guys using some sort of a magnfiying glass for your hobby? Like the ones you attach to a desk.
The one I got was closer to $100 fwiw. I'd be scared of buying one for $30, saw those and passed. I got mine from home depot online.My problem isn't that I am unable see the small stuff. It is that I can't see the stuff with my glasses on. I have to take them off. I have never thought about getting one until I saw this thread.
Is it this one? https://www.amazon.com/Magnifying-8-Diopter-Magnifier-Adjustable-Work-Black/dp/B08QJ5QVWP/ref=sr_1_5?crid=2FIEWSVDEHU56&keywords=drafting+table+light+with+magnifying+glass&qid=1689289197&s=home-garden&sprefix=drafting+table+light+with+magnifying+glass,garden,144&sr=1-5
