- USA, Georgia
- Gorgon
- Infraction
- Kraton 6s
- Notorious
- Senton 3s
- Infraction 4x4
The only movement that is there is very slight & it's in the arm pin hole & the pin. Very little. No forward or backwards movement w the shims.I found these McMaster Carr 95630A438 PTFE shims for my K6. They are 1mm thick each & really slick. These are RPM arms. I put 1 at back 3 in front & it's perfect. No slop & super smooth, no bind w the shocks off. The rear mount is the screw type & stock upper pins.
Dang dude, that does stink!Yeah, that'll definitely get rid of the fore and aft movement of the arm, unfortunately, it won't do anything for how sloppy the arms are on the hinge pins. Which is what the real problem is for me.. my brand new K8S is downright disgusting how much slop there is at the front upper arms.. no shims will help, it's the poor fitment between the pins and arms. Have a look at this RR hinge pin/plate fitment..this is a brand new rig with maybe 2 packs through it. I'm referring to the gap between the aluminum D block and hinge pins..this is poor quality IMO.
