FireDrake001
- Typhon Mega
Curious if the max 5 g2 could withstand being in a losi 5t with moderate gearing. Anyone done this?
Agree. It might struggle on 8S though unless you keep it geared conservatively.On 12S with a 56118 certainly
Mind bottling how the DBXL-E runs off the Firma 160, must be a pooch.Agree. It might struggle on 8S though unless you keep it geared conservatively.
Oh it is. It’s geared slow from the factory probably for that reason. You can pinion up knowing the ESC will die someday. XLX2 wakes that stock motor up big time.Mind bottling how the DBXL-E runs off the Firma 160, must be a pooch.
Have you tried that same setup on 8S? I’m curious how it compares.Took out my dbxl yesterday with the max 5 g2 on 12s and hit my first backflip. Feels pretty good though I'm thinking I can gear up a little more.
Nah I haven't. I did try that with the max 4 in my mcd RR5 though. First time I took it to bmx spot I had it on 8s and it was struggling, definitely felt underpowered and going to 12s made the buggy feel so much better.Have you tried that same setup on 8S? I’m curious how it compares.
