Big Rock Kaladeth’s Big Rock 3S
Correction! When I eyeballed it, it looked the same as stock, but after installing it, it does allow for bigger gears! The biggest I was able to fit was a 30T. Not the 33T I wanted, but still a big step up from 25T.
Made some big changes to complete the 8S transformation to support speed running.
Biggest change was to remove the slipper. Bought a slipper eliminator from eBay and paired it with a 57t spur gear from SaGa:
Installed Hot Racing aluminum center driveshaft.
Swapped out the badlands with PMT road tires.
Bumped up the BEC voltage to 8.0V on the ESC.
Finally, installed the 8S battery.
Some more detail on the 3S to 8S journey:
https://www.arrmaforum.com/threads/here-we-go-😂.69122/
Hit a top speed of 68 mph today. More to come!
Got the RCP fans installed!
Tilted because of the design of the RCP fan mount / clamp. This puts the fans in the way of the center bar so for a long term solution I will need to file down a part of the RCP mount, or make a custom fan mount, so that the fans sit more vertically.
Took the opportunity to check the gear box too after one pack, the gears and bearings are looking good.
Looking forward to taking this out to the local parking lot later today!
