slick2500
Anything will break if you drive it wrong enough.
Community Leader
ArrmaForum Fan
- Rapid City, SD
- Fireteam
- Kraton 6s
- Kraton EXB
- Outcast 6s
- Senton 3s
- Typhon 3s
Word on the street is these workAnd... the rear diff is done. Not sure if it's from the impact that shattered the outdrive cup or what. I didn't notice it until I was replacing the hinge pin braces and was spinning the diff to check the bearings. It caught in a spot. Upon further inspection, the tip of one tooth is gone and the one next to it almost looks sheared. The shims behind the pinion are gone/ground up into almost nothing. I wasn't even really on the throttle when it broke.
Definitely tired of arrma diffs... I've gone through more diffs in this thing than I have my other 3 electric trucks combined. Almost glad there's snow on the ground as the outcast is going on the shelf until spring... unless it warms up and the snow goes away.
Going to order another diff and just go back to stock cup on the rear, shim it and just not think about how annoying these alloy cups have been.
Anyone tried another companies gears in these diffs to see if they fit? Tekno, mugen, losi? Just curious...
https://www.amainhobbies.com/mugen-seiki-htd-differential-gear-4-10t-muge2238/p587568
https://www.amainhobbies.com/mugen-seiki-htd-differential-gear-2-20t-muge2239/p587569
The diffs in these are weird, I see people shredding them all the time, then I see people beating the snot out of their box stock trucks and not having any problems. My diffs have all been destroyed either by user error or something else failing. My first set of diffs I destroyed when I first bought it, self righting and constant standing backflips are killer on diffs, the second diff was taken out when the outer pinion bearing fell apart, the second set was taken out when my motor grenaded mid back flip and the last one failed because the diff cup came off..... I keep losing diffs in my Lc Racing vehicles for this reason, even with red loctite those damn pinion gears work themselves loose I don't get it.
