Infraction Infraction V2 GTC Porsche 917K XL Project
Diem Turner
Yes...I have a Premium Member
Rig of the Month Winner
Wienerslider, Germany
  1. Infraction
  2. Kraton EXB
Some last parts I was waiting on just arrived today so I thought, maybe the time has come to start a build log...so here we are. Below are a few pictures of the stripped down car, the platform on which I'll be building. I'll get into the other parts as I add them.
Partslist:
Chassis, Center Brace & Servo Mount : Scorched RC GTC carbon fiber
Motor Mount: PPS
Spool & Ultra Stiff Springs: Joe Diaz
Center Drive Shafts: PerfectPass V2 carbon fiber
Dog Bones & CVDs: Scorched RC titanium
Ball Bearings: Fully kitted with Scorched RC Ceramic Hybrid Bearings
Front Knuckle Arms & Tie Rods: GPM
Steering Assembly: Scorched RC Servo Saver Delete, Titanium Ackerman Plate & Flanged Ackerman Bearings, ARRMA ball bearings
Servo: HRC Racing HV Titanium 44Kg, Scorched RC Servo Mount
GPS: SkyRC GNSS & 3D Printed Mount
Splitter: Homebrew Polystyrene
Miscellaneous: Aluminum L-Profiles w/Neodymium Magnet Side Body Holders
Edit: NO, I will not change the date on my camera 🖕:ROFLMAO:
After a long wait, my set of Powerhobby Grippers finally arrived today. I detailed the sidewalls with a dab of paint pen and the look is completed with a set of Team Associated wheel nuts in blue.
Here's what she looks like head on:
Side view with some XLX2 side boob:
XLX2 has been upgraded with a Powerhobby 50x50x28mm high output fan, 8mm bullets and pigtails for a cap pack:
Starboard view of the TP 4080 2022KV powerplant:
Here's a closer look at the "engine compartment". For those wondering about the green blob under the motor, it's half of a silicone mold from years ago that I placed under the butt of the motor for support because the can (isn't that a euphemism for butt?) on this thing is long.
One last pic of the entire rear end (I swear to God...I'm not doing this on purpose):
For the eagle eyed among you who are wondering what that is on the end of the motor...I erroneously ordered the open instead of the sealed end cap, so I fabricated my own endcap from the cardboard tube from a vape atomizer and an iced tea plastic bottle cap and painted it black like The Rolling Stones:
View attachment 220072View attachment 220073
Nice build!
Red, white and blue theme?
Continuing with electronics, cap pack was installed. No, Bittydesign does not make cap packs. It's a Dr. AB Racing 15000µF 8S cap pack. At some point the printing on the label had rubbed off and I saw that one of my Bittydesign decals fit perfectly.
I mounted the electronics box vertically to provide adequate clearance for lipos for future 8S parallel speed runs with 4x4S CNHL packs and two NMB 28,000rpm server fans bolted to a Powerhobby 2x40mm fan mount.
My 4000mW signal booster finally arrived today and got everything strapped to my 7PXR with a 1500mAh 3S lipo.
3AM, Build is finished. Up front I have two sets of 3W/LED head lights connected to channel four on the receiver.
Electronics box is buttoned up and stuffed to the gills with Castle Creations Futaba Telemetry Link & Direct Connect Duo, channel 3 is connected to the AUX input of the XLX2 controlling max power output and, to round it off, a Futaba SBS-01T Temp Sensor. I've removed the cooling fans for initial testing. Gearing set at 30/31T:
Bringing up the rear is a 4000mAh LiFePO battery that powers the head lights and an ultra bright Fischer bicycle tail light:
For initial testing I've thrown in a pair of Zeee 6000mAh 3S lipos. Here she is with a full load out. Time to take her out for a spin!
