HobbyTownArrma
- BigRock
- Nero
Ive driven my Nero countless times without snapping them, how can I fix it so they stop snapping?
It's only happened when all diffs are locked.hmmm...tell us more about the circumstances...diff lock conditions .... ...etc when this is happening. ..
I'll be curious to hear how that works out.Same problem here with my Fazon.
I have ordered Hot Racing NRO288V02 CVDs and also SRVO415SP Which are the locking pins for traxxas Erevo produced by Hot Racing.. I think it can't get better than that. But nothing can be said now until trial
I'm planning on making an upgrades Post regarding my Fazon including new motor new CVDs New pins new rockers new rocker posts new SCR belted tires New T-Bone Thrasher bumper.. hopefully I don't spend a penny more than all of that to really get my Fazon to ROCK AND BASH like hell
What's the part number to the rocker posts the aluminum ones you got
thanks! I got the Nero 6s with Diff lock I've went threw 8+ Locking pins & a Rocker post looking to strengthen my nero as much as possible I see you mentioned something about Erevo Rocker posts are they more durable?NRO27M01 from hot racing
Yha
I'm order these up & do this doing a lot of forum reading trying to get the most out of simple easy upgrades members suggest the most frustrating breakage im dealing with is the drive shaft locking pins the Arama ones just don't hold up when you lock the diffs im thinking of trying the Revo pins like you suggested... I did buy a set of HPI SAVAGE pins but found they were much to thick but if they fit I was going to be such a happy camperYeah definitely they are.. hot racing
RVO2706
Both of them are aluminum but the erevo's are thicker a bit. + you will need to drill the hole for M6 thread because arrma's is M5. Myself I drilled no more than the tip of the drill bit and when trying to screw it in place it went in no problem. The thicker thread will make its way in. No need to disassemble anything at all. Pretty easy to do.
