- Notorious
- Talion
- Typhon 6s
For example on a Typhon, I see people going up to Mojave size tires which are around an inch taller. At what point does the length of the shocks create issues?
Oh....nothing....yet.What we building?
Guess I didn't read between the lines either..The Mojave tires are sick I would try those. Either that or put hex extenders on and run kraton 4s tires that could be good.
I realize now I didn't even answer the question at hand. Please ignore my lack of reading lol. But my statement still stands about the tires
Interesting I went to a lot of trouble getting fuel line to dampen the drop from jumps on my Kraton. Reason was to avoid the front drive shaft from coming out when the front dives on breaking or landing. But I guess in my scenario the shocks are not necessarily bottoming out every time.I don't know what the max tire size would be dimensionally speaking, that will vary by model I bet.. My belief is that, the chassis should touch down "before" the shocks bottom out. If not, you will damage the shocks,standoffs or shock shafts.
The droop screws won't come into play in this scenario, they prevent over extension of the shocks, driveline angles too.
Basically, as long as the chassis bottoms before the shocks, you're safe..
What we building?
Not just the shocks you don't want your drive shafts bottoming out in the diff cups before the chassis hits the ground either this is a good way to bend or break the driveshafts.I don't know what the max tire size would be dimensionally speaking, that will vary by model I bet.. My belief is that, the chassis should touch down "before" the shocks bottom out. If not, you will damage the shocks,standoffs or shock shafts.
What we building?
I too have had the dogbone ejection from drive cups on my kraton, if thats what you're talking about? Mine would pop whenever the front suspension over compressed..PIA!! Iwas stacking o rings on the shock shaft, outside the shock body to try and prevent it..helped, not solved though. Some minty fellas here on the forum (@Camaroboy383 ) told me to ditch the spacers behind the pivot balls..bam!! No more dogbones popping outInteresting I went to a lot of trouble getting fuel line to dampen the drop from jumps on my Kraton. Reason was to avoid the front drive shaft from coming out when the front dives on breaking or landing. But I guess in my scenario the shocks are not necessarily bottoming out every time.
And split drive cups! Good pointNot just the shocks you don't want your drive shafts bottoming out in the diff cups before the chassis hits the ground either this is a good way to bend or break the driveshafts.
Yes obviously I was speaking from a racing standpoint, but bigger circumference wheels will need droop adjusted/preload/oil wt/alignment to gain the same amount of travel and static centerline. From a bashing standpoint, you have much bigger problems making an impact at the upper wheel/spindle/top hub with larger diameter tire than the original geometry designed.The droop screws won't come into play in this scenario, they prevent over extension of the shocks, driveline angles too.
