I am looking for a new ESC for a Granite 4 x 4 3S
Most of the components are the same, but you lose other features like the additional tuning, turbo, heatsinks, etc.Is this the exact same thing as the Max 10 SCT? Old model moves down a tier?
Might be a little too weak for that truck. I’d totally use that in something like a Gorgon or Traxxas 2wd though.
For racing/track use (you'll be on 2S anyways) then the 80A is more than enough.How about the 80A version?
No kill like overkill. Get the most excellent Max10G2 combo with the 3665 motor. 3200 if you wanna stick to 3s or 2400 for 4s action.
But the 10BL120 G2 is the way to go for your rig.
10BL120 combo is the cheapest I would go. Max 10 G2 is a lot nicer with the sensored setup and bigger motor, but it's definitely overkillThank you @cancelthefuture!
I am thinking of 3S bashing. Are there any less expensive options to the Max10 G2 combo with the 3665SD 3200kv $173 that you would recommend?
Or is the Max10 G2 about as inexpensive as you would go?
I like that the Max 10 G2 has Bluetooth and tuning with the Hobbywing app
Cheers
Thank you @CosmoM3!
What motor would you recommend with the 10BL120 G2 (2S-4S) $59?
Requires Program Card $17
