Snacktime
- Gorgon
So this baby Max10 came with a Granite. I ran it with the 3652 motor for a 2s pack then sheared the pinion a few minutes into 3s. Currently have a 3660 3150kv stuffed in as it was sitting on a shelf.
At this point I want a 5mm motor shaft, which clearly puts me in 3660+ motor range. I would like a sensored motor, low and behold the 3665 hobbywing. The motor checks all the boxes except more amps than I think this esc will handle.
Is there any difference between the 80amp and 140amp versions? They look identical, weights are identical and wiring is identical?
Should I roll the dice on a 3665? Or is there something better? Swap the Esc to more amps and leave the 3660 Quicrun?
