Bandit_VI
Hello everyone, I'm new here, I just got a k8 exb with a Hobbywing Max 5 1100 kv combo in it, and I tried to just make sure everything was working properly. I only have 3s 30c 5000 mAh batteries at the moment to test it, so I only ran it on 6s. I noticed that often when I would full throttle it, the esc would cut out as if it was overheating (it wasn't). But then would come back to and have full power for a bit before it would do it again. Im scratching my head a bit right now, as I'm not sure if it's A) a faulty esc B) an esc that's not calibrated properly C) the batteries do not have enough discharge rate for the system or D) something else. So I guess I'm trying to kill 2 birds with one stone here, why is my esc cutting out and what is the recommended minimum power lipos to use for this 8s system, thank you guys so much in advance, I'm still really new to 8s systems.
