- TAMPA, FL 🇺🇸
- Granite
- Infraction
- Kraton 6s
- Notorious
- Typhon 3s
I was able to bind my #6s #Notorious / #6s #KRATON with SR6100AT receivers along with AVC Technology w/ no problem!! Anyways, for my 3s #Typhon I went with the SR315 DSMR 3-Channel Sport Receiver and would be model # 3 on my DX5C receiver. Instead of a bind plug for the SR315 DSMR 3-Channel Sport Receiver you just hold a button which i did and completed the bind mode and name the model TYPHON and everything worked perfectly for my 1st session pack!!! Now before i WENT out for my second speed run but had noticed it was a little slower so I adjusted the punch level to 5 instead of the default setting from the factory which comes at 3. Ok no problem, got it to punch level 5 and went to turn on the DX5C w/ SR315 DSMR 3-Channel Sport Receiver and for some odd reason I can not turn the steering from right to left. My throttle works just find forward and reverse ok!! My servo seems to work just find but it seems like it does not have enough torque to turn the servo saver arm since it turns but only 10% instead of 100%! I just cant figure out why my steering will not run my wheels. You can actually hear my Savox trying to turn the bellcrank but it just seems like it does not have enough power to turn my wheels from left to right all of the way! Could it be my servo horn but whats wired is everything worked the first time WHEN i FIRST BINDED the SR315 DSMR 3-Channel Sport Receiver w/ my DXC5 Transmitter! I am clueless and could use some help, it would be greatly appreciated.
