Captain Blaster
- BigRock 4x4
- Kraton 6s
Can anyone recognize or identify this terrible clacking ratcheting sound? It sounds like gears grinding or something. You can really hear it most when it's accelerating. Coasting, sounds fine. And hanging, holding it, sounds fine. It almost sounds like when you pull off a long strip of duct tape.
Kraton 6s V5, two 3s batteries. Everything runs well, but something is wrong. I've taken apart all three diffs, checked and rebuilt and refilled all of them. (The front one had a broken pin on the sun gear which caused the housing to wobble and get scraped by the input gear; I was so sure that was it, but the noise remains. )
Could it be the pinion? It doesn't look too worn to me. And it only sounds bad under acceleration.
Thank you!!
Thank you!!
